Re: Testing the waters
Howdy Hugh<br /> I did what you are about to do last Winter. I got a 17 Foot deepv Aluminum at a real good price. I ended up pulling everything up and started from scratch. Went to Lowes for the foam,used 1 to 2 inch cores and topped her even with the ribs.(pack it tight because of vibration). I then got 3/4 inch marine plywood and laid it on top. Used 1 inch aluminum pop rivets and fastened to the ribs. Don't know your base but this worked great for me(should last for the rest of my life). Foam isn't that expensive (out with the old and in with the new). Plan on alot of patience because its alot of work. Ended up painting it with Dupont Char Met flake and it turned out great. Good luck and I must say that The next time will never happen. To much aggravation.
