Re: Performer Vagabond?
Couple of things you can do to maybe save the resin...
Since its unopened this first tip may not help too much, but it couldn't hurt either...
Flip the container over on its lid to maintain a wet seal around the opening...
Keep it in a cool dark place, light and heat are its enemy...
When you are ready to give it a go again, you may have some crystallized resin in there, but as long as the majority of it is still liquified, you can remove the "lumps" and use the rest...
The MEK-P is the most susceptible to going bad, but you can extend it's life somewhat by putting it in a couple of zip lock bags and storing it in the fridge...just be sure to let it reach ambient temperature before trying it out...
After all is said and done, mix up a small test batch and see how it performs...
