Okieboatguy
- Jul 28, 2012
- 204
Ok, this is my first post since I have not seen this really covered in other forums, and I need some insight and knowledge above my current level. I am going to be replacing the floor of a 1984 Bayliner Capri along with the stringers. I know that marine grade plywood uses the waterproof glue and is a much more solid,ie it is more dense, and is made of harder woods and has no gaps unlike the pressure treated. I know pressure treated is made of softer woods so the chemicals can get the into the grains easier and protect it from rot, and it is made using the same waterproof glue as marine grade. The down side of using the pressure treated plywood is the chemicals that will leach out in the water like arsenic and that it is not as solid. The fact that I never want to replace the floor again my instinct is to use the marine grade, but since I have a tendency to over build I am also planning to be fiberglassing the top, bottom and sides of the plywood that is going in to completely seal the floor to prevent the issue from ever happening again. So with that said does it matter the type of plywood I use, and could I even use a non treated hardwood plywood like oak or hickory since it's going to be sealed anyway? Also, I will be putting floor drains in, something Bayliner forgot to put in, to help properly channel out the water. As well as any wood that goes in I plan to place at least a single layer of fiberglass on, and if it is exposed it will get additional layers and gel-coat. My goal is to have removable carpet, and be able to pressure wash the inside if needed like my last Carolina Sludge I used to own. So what are everyones thoughts, and where am I going wrong in my thought process? Am I over thinking what needs to be done?
