Re: can I replace my aluminum bolts with ss ones on my Starcraft transom?
If you EVER want to get the bolts back out, be sure all mating surfaces are coated with 5200.
Otherwise, the electrolysis causes the ss and al to literally WELD together. There will be no way to break them loose later on.
I had to throw away aluminum cylinder jugs on a seadoo 787 engine because the ss bolts had a thicker "neck" than the threaded part, for maybe the last 1" before the hex cap....they welded themselves into the jugs. I had to toss them and buy replacements.
And, since I had already ruined them, I decided to take them to a friend's machine shop and try to pound them, heat them with acetylene torch, mill out the centers, etc. Never got a single one of the 12 bolts removed. They were THAT permanently fixed.
So use ss on al, but lube it up REALLY good.
