Re: Transom Repair 1979 Century 3000
Well I have removed the deck and foam exposing the rear wall of the transom all the way to the fiberglass floor of the boat. I have a photo showing the transom area and then a diagram (sorry it looks like homework!) trying to explain what I found. I totally expected to find one large piece of ply covering the transom area end to end. I did not. You can see from the diagram, there is a large center piece, then a smaller piece where it is doubled up (with the cutout for the transom mount), then two wings that go to the port and starboard corners. there is no wood, as shown in the outside lower corners.
Is this normal? I mean Century made good boats....its held strong for 32 years so I guess it works!
Now, the port side down by the floor is where the large single piece is rotted. This is the spot the stringer for the motor support ran into the transom. Can this be patched? or do I still need to rip out the 37x32" piece?
If the center piece is ripped out and replaced, It seems I could leave the intact "wings" alone.....agreement?
The other side of transom is dry and solid. Both the upper "wings" of the transom pieces are dry and solid.
you can see the verticle
line where the center piece
of the transom is separate
from the 12x22" piece .
these pieces were all
glassed over.
starboard
port
all advice appreciated....obviously this is all new to me...
