TruckDrivingFool
- Jul 30, 2007
- 1,818
I bought this boat about a year ago with the non running 1970 115 Johnson and after getting an Evinrude 115 from my neighbor for the price of pulling it off his SIL's boat and disposing of the boat, I have a parts motor and have the Johnson running.
I know the transome is weak as it flexes in the middle when I bounce the motor. I think this is from the drain hole in the splash well and a bilge drain hole that was just drilled through and left bare wood w/ the exception of some silicone smeared in the hole. The floor has been redone at some point but has soft spots and the layer of FG is delaminating in the middle. The stringer I can feel through the cutout that a PO made for a bilge pump, Is still wet to the touch even though I've had it sitting covered since I got it. So all in all I know it basically needs gutted and redone.
I've sold my tinny (sold faster than I thought it would) to finance this and since I now have it running I'd really like to float it to 1.see how bad it leaks and 2. to take LOML on our traditional fishing trip for her birthday. She loves to fish but hasn't been in the last few years for lack of a sitter for our youngest daughter.
I've never done any glass work before but as with about all of us reading many of these threads I'm handy and have plenty of tools and woodworking equipment. So I may be in over my head but I have faith that I can pull through and do it.
I remember reading a thread that said 5 gal (I think) of resin was a good starting point but I can't find it again to verify and get the cloth and csm recommendations.
So if someone would give me a good starter materials list from US Composites I'd appreciate it.
I'd like input on correcting the less than stellar work done on some kind of repair at the base of the transom on the outside. Is this just something that just needs sanded out?
I don't have the room to pull the cap and this will most likely all take place on the trailer. So I'd like thoughts on where I will need to cut out the splash well.
I'd also like your thoughts on perhaps band-aiding the transom to make a few outtings w/ it on a no wake lake. I had thought of just getting longer bolts for the motor mounts and making some quick cross braces across the inside of the transom out of 2x6. What do you think?
