Welcome Guest - Sign Up today
No announcement yet.
Anything special about sealing a bolt hole?
  • Anything special about sealing a bolt hole?
    1997 Silverton 310, solid fiberglass bottom (non-cored). I thought I was getting a small trickle of water into the bilge from poorly sealed threads on the drain plug in the cabin. After cleaning up those threads and putting some teflon tape in there, I saw that the trickle was actually coming from one of the bolts in the drain plug fitting. I contacted the manufacturer and confirmed that the hull is solid, which I think (hope)makes my job pretty easy, right? I was thinking of pulling the boat out of the water this weekend, removing that bolt, coating it with 5200, and putting it back in. However few things are as simple as they seem on the surface. Is there anything else in particular I should be looking for/doing during this process? Is 5200 a decent choice for this application or should I try to keep the bolts removable with something other than a saw?
    Thanks!
    Dave
    ExitUs, 1997 Silverton 310 Express w/ twin 5.7L alphas
    Flare, 2007 Nordik 275AD w/ 5 hp Merc (ExitUs dink)
    Re: Anything special about sealing a bolt hole?
    5200 is fine for bolts, its just a sealant, its not permanent loctite.
    A wrench will remove the bolt in the future , no matter what .
    sigpic
    See FAQ Files.
    https://forums.iboats.com/showthread.php?t=299680
    Get the genuine factory service manual.
    www.outboardbooks.com
    • #3
      Agree. 4200 if you're particularly concerned about being to get it off again someday.
      2002 20' Hydra-Sports 202DC 200HP Yamaha HPDI
      1976 18' Starcraft SuperSport 90HP Evinrude
      Restoration thread https://forums.iboats.com/showthread.php?t=357767
