1963 16 ft Starcraft Jupiter restoration
v8mgbal
Re: 1963 16 ft Starcraft Jupiter restoration
Hello all, great day 70 degrees and low humidity so its painting time. I got the first coat of white on the hull and waiting for it to dry. I am now thinking that I should have cut the decking before I flipped it to paint and I could have worked on that while waiting oh well here are some pictures.
v8mgbal
another shot.
v8mgbal
and one more till next time:D
mdgpl
Perhaps you stated before, but are you rolling or spraying?
What products have you selected?
jasoutside
Looking good, great progress!
v8mgbal
Thanks guys, I am just trying to keep up with FS LOL.:D
fshngho
Hey I'm not racing you!! I discovered the same thing as you, I should have cut my floor before flipping.:mad: I still have the consoles to strip and trim I can buff out. The paint looks great V8. Looks like another HECK YEAH moment.:D
v8mgbal
What products have you selected? I am rolling and using POR-15 paints because I have been using them for many years and like it tuffness. I used it mostly on cars but thought I would give it a try here as it was designed for the marine environment .
tgp***
Wow! Your really moving along. And its looking great, too. You'll be on the water before ice is on the lake here in Wisconsin, at your pace. It took me a year to get it into the water. It was worth it, though. Keep up the good work.
fshngho
V8 I used Interlux Pre Kote (after ZC) and Interlux Brightside. I rolled the pre kote and sprayed the brightside. I bought a HVLP sprayer at HF for $50. and it worked great. A lot faster than rolling and very little overspray. Remember to have a mask on though, the overspray coats lungs too.:eek:
I don't see any reason to not use POR paints. I think of all the paints used on here, if the boat is trailered and it stick to the aluminum primer, why not? Are you using the same thing for your trailer?
Again, its looking good my friend, keep it up.
v8mgbal
Thanks guys, I may have to make a trip to HF because I have been thinking about spraying the second coat but my trouble is where to spray it. I could try to do it outside any thoughts on that. I go to pick up my trailer from the blaster tomorrow and it will get painted with POR paint also as I gotta take advantage of this cooler dry weather.
sprintst
Spectacular work man. I love the POR15 product and never did get around to doing my trailer.
It looks like the marine version of the POR will kick butt too.
v8mgbal
Hey who says you can't work on the inside of your boat when its in turtle mode:p
v8mgbal
its kind of like working in a submarine LOL.:D
v8mgbal
Hello all, I got the trailer back from the blaster today and got a coat of primer on it so now I need to decide what color to paint it.
v8mgbal
this is a tilt trailer so its two pieces. the other half.
jimdd810
Ive always been partial to fire engine red. Then again I am a volunteer firefighter/emt so every thing looks good fire engine red! :)
v8mgbal
Red is nice but I am leaning toward black or a dark blue. hmm maybe I will flip a coin:D
