Re: cleaning aluminum gas tank
I cleaned mine first by removing the sending unit (opening is about 1.5"), then pump out the old gas. leave a little amount, then tie a piece of lint free fabric (micro fiber) to the end of a firm piece of wire. Allow the fabric to soak up the residue. pour some acetone , then a little gas and continue the procedure for about three times. I waited until the inside is dry then use a vacuum, with the hose modified to go through the sendind unit hole. This will remove any additional debris
