marybethwise
- May 5, 2010
- 2
We set out to replace the carpet on our 1989 Sanger boat and found the plywood floors underneath damaged due to water rot. We have since replaced the plywood ourselves with marine grade plywood and have secured it in place.
The problem is the plywood does not cover the entire width of the boat. There are gaps on the side. The gap slopes downward toward the middle of the boat making it hard to fill.
What do you suggest we fill it with before we begin the fiberglass process?
