Welcome Guest - Sign Up today
No announcement yet.
1962 Shell Lake Boat
  • 1962 Shell Lake Boat
    I dont have a lot of information on the boat yet, as i just picked it up this morning. I do know it is a Shell Lake Co. Boat and it is belived to be from 1962, came with a small Mercury 20hp 200series motor on it.
    Just cleaned the inside out today and snapped a few pics. The resto project is about to begin, and i dont know a thing about these boats. Any info would be great. Thanks!
    1962 Shell Lake 15' Runabout
    PM me if you know much about this boat!
    Re: 1962? Shell Lake Boat
    I no nothing about the boat, other than it is Beautiful. I loved it back when the boat manuf. designed their hulls to look like high end auto's.
    • #3
      Might want to dig around through here :http://fiberglassics.com/default.htm
      Life may not be the party we hoped for, but while we are here we might as well dance
      • #4
        Re: 1962 Shell Lake Boat
        Thanks i think she is a beaut as well.
        Thank you for the link i will check it out.
        Now i need to figure out a new motor for it. Anyone know how big i should go with it? I dont want to over power or have a big heavy motor for it, but would like something with enough get up and go. I did find a '68 85hp johnson locally, that came out of a '68 15' shell lake boat, that also comes with everything including the cable steering set up. I would assume that since the 85hp came out of a 15' that it would work well in mine. Opinions?
        Motor:1968 Johnson 85 HP Model V4A-V4AL-20A
        Any opinions on the motor?
        • #5
          great looking boat......and a super candidate for resto......
          read the uscg rules on max rated hp.....there is calculations to figgure out the max rated hp.......the depends on the legnth times beam.....an 85 is about right.....
          how are the stringers and transom?
          The Hull Extension Thread
          great info on all aspects on boat building with detailed information.
          https://forums.iboats.com/showthread.php?t=234392
          IN MEMORY OF Our friend SpinnerBait_Nut LESTER WRIGHT July 31, 1953 - Nov 26, 2008 RIP
          IN MEMORY OF Our friend Tashasdaddy Robert (bob) Griffis. October 27, 1948
          November 29 2010 RIP
          • #6
            What's the length on it? I have a 16' aluminum starcraft and it's max rated at the 85 I have on it. I think a '68 Johnson had electric shift which can be an issue if a shifting solenoid goes bad as they are no longer available. I believe you gotta go '73 or newer to get away from electric shift.
            2002 20' Hydra-Sports 202DC 200HP Yamaha HPDI
            1976 18' Starcraft SuperSport 90HP Evinrude
            Restoration thread https://forums.iboats.com/showthread.php?t=357767
            • #7
              I think i am a little ahead of myself on the whole motor thing. After going over the boat with a fine tooth comb i think i will be replacing the floor. I found 1 weak spot where it has rotted away. I have yet to remove the old motor and examin the transom further, i did take off the aluminum end caps and the transome appears to be well. I will be taking the floor out later this week and begin the replacement. In the mean time i am studing Runabout Renovations by Jim Anderson, and i am learning a ton! I just hope i can get thru this floor replacement procedure. Again any advice from you guys is more then welcome.
              • #8
                I just bought a 1961 runabout last weekend for $100 trailer included and i'm also in process of ripping up the deck to replace the stringers.
                1967 WestWind "Aerodyne" 14' Runabout
                sigpic
                Just Keep N it Reel!!!
                My restoration in progress
                • #9
                  Thats just what i found out tonight. I took the main floor out this evening and found that the 3 stringers were rotten.
                  Also took the motor off and transom cap and found that 1/3 of the transom was also rotten. So that will need to be replace as well. I will have more progress pics up tomorrow, right now i am tired and am going to bed. KeepNitreel, i will PM you.
                  Josh
                  • #10
                    updated pics. Took most of the floor up to find rotting stringers, pulled the motor off to find rotting transom.
                    My one question is, in the front of the boat you can see where the stringers go near the front, and under the bow of the boat, to an area where there is just fiberglass no floor. Do i need to pull up all that fiberglass in order to get the stringers out and replace them?
                    • #11
                      The curves on the transom are sweet! What color do you plain on painting her?
                      sigpic
                      • #12
                        yea i love the curves on the splash well. We havent decided yet, as that is quite a ways down the road. We have either blue or white in mind. But again i gotta replace the stringers and transom first, then do a bunch of fiberglass work, and find a new windshield, then find a powerplant for her
                        • #13
                          Frist and formost welcome !!! what a find !! love the looks of her !! sounds like you got some work to do on her , but when you get her done and in the water !!!!! OOOHHH MAN what a feeling !! I just got mine done to where i could to take her out last week !!!!!!!! I couldnt belive how much difference it made in her !!!!!! I did the same thing you are going threw now !! its all worth it !!!!!
                          And 85 hp does sound about right for her !! with that on you could pull two skiers on her with no problem !!! it would scoot her really well !! I am running a 1962 100hp merc on mine , got a pertty good deal on it and went and seen it before I got it and really trusted the guy [ call him uncle joe now ] got it off of ebay !!
                          So keep us post on how it going and keep them pics comming !! John
                          http://s274.photobucket.com/albums/jj258/jcsercsa/
                          STANLEY CUP CHAMPS 35-36 36-37 42-43 49-50 51-52 53-54
                          54-55 96-97 97-98 01-02 07-08
                          • #14
                            Here is a small update. Me and a buddy got the cap off the hull and cut out the rest of the floor and removed the stringers. Here are a few pictures.
                            • #15
                              old stringers and where they used to be
