Re: Upsizing Trim Tabs
Thank you, I just got off the phone with them.
They told me that, it could be swapped with out redrilling, but dumb old me had the measurements all mixed up (chord/span). Also I was told that I would have to keep the tabs atleast 8" away from where the props line up with the hull in order to avoid cavitation.
Now get this, I went to the transom to make some measurments and discovered that it's impossible to go much larger than a 12x12 tab because the transom makes a 90 degree dip inorder to accommodate the twin engine bracket, I've had this boat for almost 10 years and I've never noticed that.
Anyway the guy at Bennett suggested that I go with their DropFins (DF12) which is an even more simple solution.
And you're right the guy at Bennett was fantastic he solved my problem without making me feel like the dummy I now know I am:redface:
