I'm rebuilding the transom and I'm going to paste the first layer of wood to the hull using thickened epoxy (then fiberglass wood and more fiberglass).
I calculated how much it takes to set the transom in place and screw it to the hull, aroud 10 mins. I also tested how much working time I have with the WS 105 epoxy (around 15 mins) that means I only have 5 mins to mix epoxy and wood flour and spread it on the surfaces.. not enough!
I'm looking for way to gain 10-15 more mins, I read about using biggger pots to better dissipate the heat and I'll have a little AC system pointing against the pot while mixing as well.
I was also thinking (and this is my question) of using a big plastic bowl, put some ice in it, put another smaller bowl in it and mix the epoxy in there to keep it more cold.. does it make sense? Could I have any prob with condense of water from hot air around the cold bowl?
