Welcome Guest - Sign Up today
No announcement yet.
Reinforcing Cleats?
  • Reinforcing Cleats?
    My boat originally had the standard 4 cleats from the factory, but someone has added another 4 folding cleats for fenders over the years before I got it. The hull is stamped "Fender Only" above the 4 added cleats. I am looking to strengthen the rear folding cleats to be able to tie up to those cleats instead of the rear factory cleats. Every weekend we tie up to a larger cruiser and it is a big step across our boats. If I could tie up to the rear folding cleat it would make the boats easier to cross when tied up.
    I know the fiberglass is a lot thinner at the folding cleats (I would guess maybe 1/4'' thick vs. 1/2'' thick at the factory cleats) I cannot get to the backside easily to add more fiberglass, but I could maybe get an aluminum or stainless plate to bolt to the inside. Right now there is only a larger fender washer on each bolt.
    factory cleats would have an aluminum plate embedded in the hull for strength at the area around the cleat. simply make an aluminum backer plate about 4" x 8", retain with some epoxy and remount the cleat.
    Cheesehead boating the Gulf Coast of FLA 27.51° N, 82.53° W
    1988 Cruisers Rogue 2420 -VP 290 DP now powered by custom 468 - https://forums.iboats.com/forum/owner...988-rogue-2420
    Past Boats
    1970 Wooster Hellion - Merc 9.8
    2002 SeaRay 190BR - 5.0 - A1G2 - "Cheeseheads in Paradise"
    1984 Avanti 170DLI -3.0 stringer- "Ship Happens"
    What’s behind you doesn’t matter.Enzo Ferrari
    • #3
      I am not sure if I will be able to get any epoxy in it. It is all i can do to reach the bolts with one hand to get the cleat off. Will a plate suffice on it's own? I could probably thread the holes in a plate and have someone start the bolt from the outside while I held it in place, then add a lock washer and nut after the bolts are started.
      • #4
        mix up some marine tex and butter the one side of the plate
        or use 5200 fast cure and butter the one side of the plate
        you want the bedding compound to fill the little craters and imperfections.
        Past Boats
