Welcome Guest - Sign Up today
No announcement yet.
1978 19 ft Glasply cuddy stringers
  • 1978 19 ft Glasply cuddy stringers
    I am looking at a 1978 cuddy cabin Glasply. From what I have have read 1978 was the production year that they transitioned to fiberglass stringers. The owner is an elderly guy that claims it has glass stringers. Can I verify this without doing a core test?
    This man can help you.
    Dance with the waves,
    move with the sea.
    Let the rhythm of the water
    set your soul free.
    1987 Four Winns 170 Horizon.
    • #3
      • #4
        Okay here is a link with a similar boat. This guy says some had wood stringers some didnt. Dont matter to be sure and repair the 85% of the boat that is still wood. Transom and structural floor. Wet Foam need replaced. You still got to do exploratory surgery. And repairs. There is no easy way out. Johnny Carson was still your best bet if your just going to guess.
        https://forums.iboats.com/forum/boat...ebuild-repower
        move with the sea.
        set your soul free.
        • #5
          Thank you. I live in the town Glasplys were built and I have always liked these boats. My brother in law has one and it handles that rough chop like a champ. I want one that has the glass stringers so at some point I can repower and replace floor and transom with Coosa board. Then I should have a solid boat for years to come
          • #6
            If you're going to replace the transom and deck, may as well do the stringers as well. So does it really matter? Is there an access panel over the fuel tank, because if so, you can usually see the stringers from there. Or, in the bilge area.
            "If it ain't broke....don't worry, 5 minutes with me and it will be!"
            1988 Sunbird SWL 200 - Evinrude 130 hp Looper
            1996 Trophy 1802 - 120hp Force (SOLD)
            8' Hardbottom Dinghy w/Evinrude 6hp OB (ALSO SOLD)
            Always In the market for nice, local area, sailboat, with the operative word being-"cheap"
            • #7
              Emoney I don't plan on getting it if it has wooden stringers, shouldn't need to replace stringers if they are fiberglass right?
              • #8
                My webbcraft has glass stringers but i still had to get all of the wet foam out of them. Luckily I removed the back 12" against the transom since it had to be replaced and cut out the tops ever couple feet to keep most of the stringers intact. Then once the new transom was back in I was able to put the cutout stringers back on place and glass in. I was both happy and surprised when I pulled up the old floor. Then once the floor was back in I made sure I drilled holes into the stringers and poured in foam.
                • #9
                  Got it. Thanks for the insight
