Welcome Guest - Sign Up today
No announcement yet.
Water in the transom. or How to ruin a nights sleep for a week.
  • Water in the transom. or How to ruin a nights sleep for a week.
    About 6 years ago, I undertook the rebuild of my Stratos center console. Cut the cap off and took it down to a bare hull. I put it back together with 1708 and epoxy while keenly ensuring that all stringers, bulkheads and exposed wood was sealed.
    Yesterday I was mounting a transducer. It is an expensive enough one that I didn't want to trust it to a glued on Starboard mount so I drilled into the transom. When I pulled the drill bit out, water started trickling out of the hole. I was sure that I had sealed everything to the nth degree when I put everything back together. It was a heart breaking WTF moment.
    The transom is still solid but doesn't pass the tap test like it should. It will be fine for many years I am sure but it is nagging me and is going to get addressed down the road. In the mean time, I am just sick to my stomach thinking about it.
    In looking at my rebuild pictures, I can clearly see that the wood was completely encapsulated in fiberglass. I can also see where I left drywall screws in it from where I epoxied the 2 pieces of plywood together. That rules out using a chainsaw to remove most of the material. BTDT. It will be many hours of long drill bits, long chisels and endless cursing. I might look into using lye or similar to disintegrate the wood.
    Until that time though... I am sick.
    The difference between a used mistreated boat and Pandora's box is that in the bottom of Pandora's box there was hope. In the bottom of a used mistreated boat, you will only find rot.
    wet wood would last many many years prior to rot.
    I would make an access hole, then add anti-freeze to kill the bacteria and go boating until you feel like re-doing the transom again.
    Cheesehead boating the Gulf Coast of FLA 27.51° N, 82.53° W
    1988 Cruisers Rogue 2420 -VP 290 DP now powered by custom 468 - https://forums.iboats.com/forum/owner...988-rogue-2420
    Past Boats
    1970 Wooster Hellion - Merc 9.8
    2002 SeaRay 190BR - 5.0 - A1G2 - "Cheeseheads in Paradise"
    1984 Avanti 170DLI -3.0 stringer- "Ship Happens"
    What’s behind you doesn’t matter.Enzo Ferrari
    • #3
      That's pretty cool to know, Thanks Scott.
      Most times I'm wrong, Most times I stand corrected..But...Sometimes I'm right.
      1983 SportCraft Deep V OSFF 222 Cuddy Rehab
      https://forums.iboats.com/forum/boat-...ddy-walkaround
      https://forums.iboats.com/forum/engin...-new-fuel-pump
      www.flotationfoamsolutions.com
      • #4
        Same amount of work if you do it now or later. Wait till it needs fixing
        I would try to figure out where the water is coming from. D rings, engine bolts or other
        94 Formula 27PC Custom 509MPI MEFI3 , B3 XR
        95 Rinker 232 w/ 7.4L Carb 0F425011 B1 0F486471
        07 Seadoo GTX
        Merc Adults Only VP Adults Only
        G-Dad always said "First Liar doesn't stand a chance"
