- Jul 18, 2011
- 17,621
My boat (Formula 330 Sun Sport) has developed a rather nasty 'banging' sound in the area of the windshield when I hit waves a certain way. This has developed over the past couple of years, and I figure that I will look into it.
This year, in particular, I began to notice some gelcoat cracking in 2 spots around the windshield, which sort of gave me a good idea where the banging noise was coming from. . .
This is a spot at the forward edge of the windshield frame where the windshield meets the deck, just to the starboard side of the windshield 'hatch'.
What's below this entire area is the enclosed head (restroom), which leads me to believe that the structure of the restroom is somehow impacting the underside of the deck when I hit waves just right. If I keep the bow of the boat down hard into the waves, then it does not seem to be a problem, but that is not always possible.
So, the boat came out of the water last week, and I figure I'd start to dig into it.
The foam came up dry (which is a good thing), but there is some rot progressing from the 'mini' bilge that you can see in the upper right of the picture.
I am thinking at this point that I will do a partial floor repair, along with some 'chemotherapy' (i.e. Ethylene Glycol) treatment for the isolated dark spots. I'll have to rebuild the 'mini' bilge as well.
The carpet itself is a bit grungy (23 years old) and I plan on replacing with some vinyl plank flooring (of some sort).
I also drilled into the stringer that is directly below the wall of the restroom to see If I got any water out of there, but nothing major to report . . . The stringer itself looks solid with no darkened areas. The moisture meter comes up as having some moisture, but I think it is due to the floor of the bathroom having a leak at the seal where it meets the bathroom wall (which I will fix as well)
While I got stuff apart, I plan of checking the joints where the stringers meet the adjacent bulkheads. I haven't found anything that would point directly to the noise/cracking issue all of a sudden, but maybe I'll find something.
More to come in the next few days . . .
