Welcome Guest - Sign Up today
No announcement yet.
94 century center console
  • 94 century center console
    I have a soft spot just noticed it's about 15"x8" can I use starboard on the floor to harden it up. Just lay it over top of exciting floor or do I have to tear it up first. First time boater looking for suggestions
    Hi Bullet, welcome to Iboats.
    Not sure what model you have, but I have a 96 1800cc with a soft deck. You may find that the foam supporting the deck is saturated. Mine was getting increasingly slower due to the weight.
    I believe most of their mid 90's models were a tub construction, where the deck is molded to the gunnels. I havent dug into mine yet, its on drydock waiting
    If u try patching the area, you will need to check the foam underneath after cutting out the soft area. This can be done by tunneling a piece of pvc cut to a point and twisted down the the hull bottom to check the lowest foam sections.
    After you post a few more ties, you can put up a few pics so we can see what you have.
    "We all come from the sea. But we are not all of the sea. Those of us who are, we children of the tides, must return to it again and again."
    Current Boats
    10' tin gamefisher/Johnson 7.5hp ob
    1991 Sea Ray 170br/AlphaMerc
    1996 Century 1800 CC/Yamaha c85
    1988 Imperial 280SF (under the knife)
    1972 Checkmate mx-15
    https://forums.iboats.com/boat-restor...cs-598307.html
