Terestron
- Jun 26, 2019
- 9
What am I getting myself into? I cam across a trailered 1987 CC Amerosport 283 for $600.
The trailer is worth more as it is a dual axle.
The hull seems sound, yes it needs TLC and the berth area is moldy, but not bad. The floor seems very solid. I think it will clean up nice.
It has twin 4.3L V6 Crusaders. One will start and run when gas is poured down carburetor. The other has cracked exhaust manifolds and thermostat housing. Not sure how the block is. I am making the assumption that the engine needs to be replaced.
The props look fine and the shafts seem straight. they turn by hand. rudders look fine.
I would defiantly need to buff out hull, the is a small section that need fiberglass repair about size of my hand, and the bottom need a good bottom coat.
I do not mind doing the grunt work, and I have rebuilt engines before. and I do not mind a project. but i do not want a project that takes years. I guess it only takes money right.
I am new to boating so I guess I am looking for resources like where could a i get a good used motor? good place to get engine parts, boat parts. I know this forum is a great place to get advice.
Any constructive feedback would be appreciated.
Thanks!
Thanks!
