Wyoboater75
- Jun 5, 2019
- 5
Hey guys I'm new here and am attempting my first boat restoration. Lots of learning on the fly. I have 78 Reinell trihull that have I have gutted to the hull.
When I gutted the boat found the stringers and bulkheads were laminated foam. The foam was saturated and the glass was delaminated and split in numerous places. I cut the stringer material out and ground the hull to good glass. Next I layed down a layer of 1.5 oz of csm and a layer of 24 oz roven to built up the hull from having quite so much flex as I had to grind so much out to get to good glass. My plan is to use 3/4 inch plywood for stringers and bulkheads. Would anyone be able to provide some advice if this is acceptable to go from laminated foam stringers to wood? I want to do this resto right so it will last a lifetime.
