Welcome Guest - Sign Up today
No announcement yet.
Noob polishing questions
  • Noob polishing questions
    Thought I had this figured at but as I researched items to buy got confused. I have a 92 searay that has some oxidation. Bought the Mequiers kit with oxidation remover, polish and wax. However as I researched pads for my Dewalt polisher I got stumped on what to buy. Do you use wool for the oxidation remover, cotton for polish? What do you use for the wax? Can you use foam pads instead, for the 3 steps? If I can find hook and loop pads, can you just use the bonnets. If so how do they attach? Can you use a none hook and loop pad with a hook and loop backing plate? If you use wool pads do you risk more swirl Mark's?
    Thanks in advance for any suggestions and advice.
    1992 Searay 200BR | Mercruiser 4.3LX (SN: D826758 | Alpha 1 Gen 2 Housing (SN: 0D771909 | SEI 116 Upper & Lower Unit
    I use harbor freight wool pads. It you got swirl marks it just means your not done yet. As for wax opinions are like you know what. Just pick one with UV protection.
    Dance with the waves,
    move with the sea.
    Let the rhythm of the water
    set your soul free.
    1987 Four Winns 170 Horizon.
    • #3
      Do you use the HF wool for both oxidation and polishing? Do you apply wax by hand? Wool feels aggressive for applying wax? Thanks for your input!
      • #4
        Oxidation depending on the level of it. Sanding may be needed if it is bad. I used the pad for buffing. I hand wax mine. I use ardex ocean polymer. Work is over using that. rub it on and whipe it off with a towel.
        Once I finish buffing it just needs a UV Protectant.
        That is my way. Takes a couple hours to wax I do mine twice a year. In the spring and fall before the snow. But the directions say once a year is enough in salt water. I believe them. Stuff is amazing. I started using it on my trucks van and chevelle.
        I painted all my life. And wow this stuff takes all the work out of waxing. Hides swirlmarks, small scratches. You must see it to believe. I got all kinds of various paste waxes on the shelf that will never be opened again.
        move with the sea.
        set your soul free.
        • #5
          I used this for the oxidation removal:
          https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
          This will be used for the polishing:
          This will be used for the finishing/waxing:
          I also got this to do it all - pads stick right on:
          • #6
            Funny that I just got the last of the items on my list to do this too.
            I’m following this guy’s video to a T, including purchasing the exact part numbers. Why? I don’t know, I like his videos and I trust him.
            https://youtu.be/ZexSavaT4tY
            Im trying to decide whether to wet sand it now and then apply the compound later. My boat is outside in the rain right now and I can’t move it since the motor is hanging on a hoist right behind it. Here’s why:
            https://forums.iboats.com/forum/boat...ing-my-transom
            The rain would make wet sanding easy, but I can’t put the compound on for another week or so.
            • #7
              NatedoggAz for the links!
              Flippin out I have watched that same video and I agree I thought it was a good video. Hopefully weather cooperates this weekend so I can get the last of spring stuff done.
              • #8
                Why no Polish Questions?
                Most times I'm wrong, Most times I stand corrected..But...Sometimes I'm right.
                1983 SportCraft Deep V OSFF 222 Cuddy Rehab
                https://forums.iboats.com/forum/boat-...ddy-walkaround
                https://forums.iboats.com/forum/engin...-new-fuel-pump
                www.flotationfoamsolutions.com
                • #9
                  This pic was taken during the oxidation removal using the Meguiar's kit - just the oxidation removal alone yielded these results...
                  Oxidation on one side and shiny on the other:
                  Click image for larger version
Name:	oxidation removal.jpg
