snowbrd84
- Sep 23, 2012
- 215
Got a good deal on a '96 Bayliner 1950 that I knew had 2 soft spots on the floor but runs great. Pulled the carpet and the spots didn't look too bad. I was able to cut out the bad spots and get to dry strong plywood around both. Foam is dry and stringers look good and rest of the deck is dry.
I am going to patch the two cut outs, sand the whole deck and reglass.
My question is this, should I cut out a few more inches to reach the hull so that the patches join at the hull on the sides or just patch as is in the pictures?
Also, what type of plywood should I use if I can't find marine grade?
