G
Guest
Guest
I'm not sure where to put this post, but this seems as good a place as any. I've had great luck with the advice from you guys this forum so far. (are you listening WoodonGlass?)
So here goes:
I just picked up a 2004 beautiful Evinrude Magnum (M-1) gearcase to replace the original worn out gearcase on my 200 Evinrude OceanPro.
Its a freshwater unit, and the OMC dark charcoal paint is in almost perfect condition. no fading, chips, corrosion or bare spots.
My motor is white, and I want to paint the gearcase white to match it, but I want to do it right.
Some questions:
How do I prep the this existing finish for the color change? when the existing finish is in great shape?
Do I need to sand and prime over this original paint?
or, can I sand the existing paint with maybe a 400 grit sandpaper to etch it, and apply the OEM white paint?
I've done many outboards and drives with rough/worn/weathered/bare/corroded surfaces, but never one that's good to begin with.
Thoughts?
So here goes:
Some questions:
Thoughts?
