Not a good idea. The front bench supports the bow makes it rigid so when your on plane and hitting waves/water the bow takes the brunt of the pounding and the rear bench helps support the stern which you need the stern to be strong because thats where you are, fuel tank and motor. Most guys remove the middle bench add in floor then supports to the gunnels but its usually frowned upon and not a great idea.best of luck and safe boating
