Welcome Guest - Sign Up today
Private Messages
We are aware of a current issue where your messages screen does not properly load and we are working on a fix.
In the interim, you can access you messages by navigating to this link: https://forums.iboats.com/privatemessage/notification
Apologies for the inconvenience.
See more
See less
Tri Hull Fuel tank??? Wha do you use???
  • Tri Hull Fuel tank??? Wha do you use???
    I’m in the planning stages of my tri-hull restoration, and right now I’m trying to decide to use a permanent fuel tank or a portable one. I’d like to use permanent so i don’t have to refuel as often. My boat doesn’t have a dagger stringer (down the center of the tri hull) so i could mound one below deck. Has anyone else mounted one below deck or should i put it under the splash well? Just trying to get everyone’s thoughts. Because at this point everyone has more experience with boats than me as I’ve had mine for a week today. Thanks for your input...
    I had the largest rectangle shape under the splash well I could fit on my old tri hull. I think it was 15 gallons
    1985 Bayliner 2450 Ciera Sunbridge
    Volvo Penta AQ225d, 280 outdrive
    Restore/Refurbish ongoing......
    link to my thread: https://forums.iboats.com/showthread...468790&page=12
    • #3
      http://www.moellermarine.com/product...nt-fuel-tanks/ Once you get your structure rebuilt, measure up the space available and see if Moeller has something that will work. I bet they do.
      '96 Larson 174 SEI BR. 4.3LX 4 bbl Weber s/n 0F786604. Alpha One Gen II s/n 0F709315
