Welcome Guest - Sign Up today
Private Messages
We are aware of a current issue where your messages screen does not properly load and we are working on a fix.
In the interim, you can access you messages by navigating to this link: https://forums.iboats.com/privatemessage/notification
Apologies for the inconvenience.
See more
See less
How to remove foam after vinyl removed
  • How to remove foam after vinyl removed
    I pulled the vinyl from the sides and ceiling of my cabin but there are a bunch of spots where the foam was left behind. Is there something I can use, preferably spray on, that will make removing it easier?
    2008 Maxum 1800MX - 'Lottie-Da'
    1994 Proline 2510 - 'DrifteR ' <- project - ON THE WATER!
    1971 Concorde 27' - 'Little Angel ' <- sold
    A wire wheel cup brush on a drill makes quick work of it. Keep a shop vac hose next to it and catch most of the dust. I e tried several “liquids” and they tend to make more work.
    1985 Bayliner 2450 Ciera Sunbridge
    Volvo Penta AQ225d, 280 outdrive
    Restore/Refurbish ongoing......
    link to my thread: https://forums.iboats.com/showthread...468790&page=12
    • #3
      ^^^+1. For overhead work this is the safest method. Styrofoam, polystyrene foam, dissolves quickly with solvents like acetone, and...well, gasoline. Both have risky fumes, and leave muck to scrape off after the solvent.
      '96 Larson 174 SEI BR. 4.3LX 4 bbl Weber s/n 0F786604. Alpha One Gen II s/n 0F709315
      • #4
        Looks like the wire wheel it is... Gonna have to get everything out to get ready for the cleanup
        • #5
          A cheap roll of plastic sheeting works well to cover things. Fold up the plastic carefully when removing, use the shop vac while removing and the mess isn’t that bad. Respirator wouldn’t hurt or at least a mask.
          • #6
            I also use a cup brush in the angle grinder. just dont sit in one location for any length of time.
            Cheesehead boating the Gulf Coast of FLA 27.51° N, 82.53° W
            1988 Cruisers Rogue 2420 -VP 290 DP now powered by custom 468 - https://forums.iboats.com/forum/owner...988-rogue-2420
            Past Boats
            1970 Wooster Hellion - Merc 9.8
            2002 SeaRay 190BR - 5.0 - A1G2 - "Cheeseheads in Paradise"
            1984 Avanti 170DLI -3.0 stringer- "Ship Happens"
            What’s behind you doesn’t matter.Enzo Ferrari
