Welcome Guest - Sign Up today
No announcement yet.
1976 Cherokee boat rebuild
  • 1976 Cherokee boat rebuild
    I found an old cherokee in a barn and made a real buy on it with the intent of rebuilding it to take my dad fishing. Here she is the day she came home.
    I found a soft spot on the transom so I gutted the whole boat and replaced the transom.
    • #3
      I bought a 25' long bank sign made of 1/8' aluminum with a 3' turned edge for about $20 so I decided other than the transom it would be wood free. Took my time to get the curves and had to put it in with 3 pieces.
      • #4
        I built a rear bench/storage box out of the remaining aluminum, build a top and carpet and attach the floor in one large piece.. I decided to make the boat wide open for more floor space. I didn't have an outboard and decided a tiller would be handy on a small boat.
        • #5
          Had to weld up a spot where the old rollers had worn through the keel. The roller up front was as hard as concrete and almost as rough. Then lots of prep work and paint.
          • #6
            Pulled the center rollers out of the trailer so it loads better now
            • #7
              Added pedestals and wiring. I was able to use the original running lights and wired a thru hull bilge pump.
              • #8
                I built rod storage out of pvc wrapped it in carpet to match. It's long enough to fit my 8' jig pole. added a cheap fish finder and some millenium
                • #9
                  Nice work
                  Cheesehead boating the Gulf Coast of FLA 27.51° N, 82.53° W
                  1988 Cruisers Rogue 2420 -VP 290 DP now powered by custom 468 - https://forums.iboats.com/forum/owner...988-rogue-2420
                  Past Boats
                  1970 Wooster Hellion - Merc 9.8
                  2002 SeaRay 190BR - 5.0 - A1G2 - "Cheeseheads in Paradise"
                  1984 Avanti 170DLI -3.0 stringer- "Ship Happens"
                  What’s behind you doesn’t matter.Enzo Ferrari
                  • #10
                    Excellent work! Makes me kinda want a tinny
                    1985 Bayliner 2450 Ciera Sunbridge
                    Volvo Penta AQ225d, 280 outdrive
                    Restore/Refurbish ongoing......
                    link to my thread: https://forums.iboats.com/showthread...468790&page=12
