A couple of weeks ago I was given my Dad’s boat, it is a 2001 Glastron GX185 SF 18 foot ski & fish.
This was my family’s boat growing up in California, so there is sentimental value in the thing. I have no money invested in it…YET.
I knew that the boat was old, and that it had been sitting outside in storage lots for about 10 years without proper (any) maintenance and was left to waste away without cover, etc…essentially severely neglected. I also think I know that it was not winterized ten-or-so years ago. I understand that meant the block was probably going to be cracked.
When it was my Dad’s boat, and in better shape in 2013, I had a very reputable mechanic check out the engine. Both exhaust manifolds were cracked (cast iron). The mechanic was nice enough to run a compression test on the engine: a Volvo Penta 4.3 Gi. It apparently had compression, cranked, and wanted to start but the fuel pump was shot. Dad ordered the fuel pump and the intake manifolds (both). They were never installed, I have all of that in my garage with all four gaskets and all of the bolts.
I am a newbie. Over the past couple of weeks, I have read countless articles on restoration of boats in such condition as this Glastron is in.
Last weekend I power washed it out (it was full of leaves, dirt, and debris. I started to strip the boat of the rotten and broken parts, accessories, as I understand is SOP for investigating.
Throughout the week I read numerous topics and watched numerous videos about replacing decking and stringers. I found that *it seems* that the 2001 Glastrons had a VEC hull, meaning potentially no wood in the transom or wood stringers. This would be a good thing if it were true, considering how long the boat sat out in the weather.
The engine has 63 hours on the gauge.
Tonight I pulled the rest of the seats out, and pulled up about half of the carpet in the main area of the boat (pictures can't be attached because I'm a new user I think). I found that
I don’t know what question to ask and where to start, but here are my questions
Thank you,
- Daniel
- The carpet is easy to pull out, it’s so degraded it rips
- The deck is rotted out in the center area of the boat
- The perimeter of the boat is fiberglassed about 6-9” inward, wood underneath is bright yellow
- The deck seems to sit on 2x4s running port-to-starboard
- The ski-locker has what I might imagine to be a single dividing piece of lumber or what might be a wood stringer running port-to-starboard.
- The engine would take some money to get running, because there is likely a $1,500 of belts, additional misc. parts, and labor needed to get it running (it ran 5 years ago - I’m being hopeful or blissfully ignorant). I would pay someone to do this
- I could possibly do a re-deck project myself, especially since the perimeter 9” is clear
- The carpet would be a long weekend project
- The gauges and batteries could be done by me for a significant cost but would be a fun learning project
- Do I have wood stringers in this boat?
- If I replace the deck with marine plywood, would I just have to replace the interior section within the 9” of fiberglass?
- Am I right about the engine, if 5 years ago it had compression it should still if it has not been introduced to water?
- What would you do?
Thank you,
- Daniel
