czsilverwolf
- Dec 31, 2018
- 19
Hello,
I am new to fixing and maintaining boats but by no means new to boating. I just bought a boat and I am looking to get it fixed up and repaired. I will have each item I need help with separated out into list file. If you can help me or link me to help I would greatly appreciate it.
1. First things first is finding manuals. I need an operators, parts, service and an engine manual. The problem is the Hull ID ends in 79' but the title lists the year as 80'. Looking through sea rays brochures (cuz they don't have any manuals pre-89') the closest boat based on layout and length of the boat (22.5') is the 80' SRV 225 Cuddy Cruiser (except I don't have a refreshment center). Another problem is I can't seem to reverse lookup the serial numbers on the engines to see what they are. Serial number on the stern drive is 5331357 and the serial number on the in/out engine is 5492908. Any manuals or ID help would be greatly appreciated. Can't do much with the engine without a manual to show where everything is and how to service/maintain it and what fluids to use. It is a Mercruiser V8 in/out with a stern drive propeller, but that's all the info I got.
4. Electrical wiring replacement. Any advice for where to find wiring diagrams for my boat as well as where to find replacement wires would be greatly appreciated. I would also be interested in adding extra lighting to the cuddy cabin. The control panel also needs some switches replaced but don't know what they turn on/off yet. I do plan to remove the cracked laminate on the control dash. Should I replace it or just remove it?
5. Sealing cracks. I did find a post about grinding out and sealing cracks but he used a blue colored filler. Is there a white version? As you can see the whole thing already got sealed in the past in a straight line under the rails but it's cracking in some parts.
6. Re-oiling the teak wood. Any recommendations for sanding and oiling teak wood parts? Also need to find a replacement door for the back of the cuddy cabin since it doesn't have one.
7. Seat cushions. The seat cushions are in good condition and just need steam cleaning and resealing. Any recommendations for a seat cushion sealer/varnish?
8. Trailer. Is there a good paint for boat trailers or will any paint do? Also need to rewire the trailer.
9. Parts. Not necessary but I would be interested in finding a replacement canvas cover (as seen in the cuddy cabin) that snap into the window frames or a replacement refreshment center.
That sums up what I need help/advice with. The rest is just parts and cleanup. Any help is greatly appreciated.
