76SeaRay
- Aug 24, 2017
- 1,047
This is what I found when I opened up the floor to replace the transom. I cut the floor back about 8 inches away from the transom and cutout the floor and stringers. Here are the port and starboard cross sections of the floor and stringers. In the picture labeled stringers port A, I annotated it with where the question exists. That is, should the floor be left essentially floating where the arrow points? Would it be better when I replace the stringers to support that point from the hull. As you can also see there is only a little bit of plywood that supports the engine mounts, at least it seems that way looking at the cross section.
