Chris51280
Ensign
- Jan 24, 2018
- 908
look at dezmond since he does his with epoxy.
Stupid question time!
So I have been reading and watching videos for a half hour or so on laminating the transom. I have two questions.
1. Do I just use the epoxy resin or do I add hardener? Seems simple and straightforward but no where have I seen anyone specifically mixing resin and hardener.
2. I'm going to use PL to bond the two 3/4" slabs together. Should I do this before or after laminating? Thinking of all of the fun stuff that I have to screw into the transom when I'm done makes me cringe and I want this as waterproof as possible. Ex: the rot on my old transom originated in a few spots. One was the screws holding in the starboard trim tab. I do not want to make that mistake.
I have 1/4" thick outer skin to work with, so I'm doing 2 3/4" sheets on top of that followed by 1/4" of inner skin, which will get me in the ballpark of 2". I'll lb the wood to the outer skin once laminated, then tab it in followed by the final layers of skin.
So I'm done working for the week and I won't be able to work again until April. I got the hull ground out and cleaned up and got my transom done.
I have a few comments:
First, harbor freight tools have been great so far, but the drillmaster jigsaw-two thumbs down, zero stars, 0/10! That thing worked better as a jackhammer. I had very fine blades on it and it destroyed the wood. I got a Craftsman and everything was fine.
Tyvex were not worth it. Every one I had got a hole in it within 5 minutes of being in the boat. I ended up wearing a pair of Dickies work pants and a poncho followed by an old jacket. This worked well. When I got fiberglass all over myself with the suits, what I did when I got home was take a steaming hot shower, cover all affected areas with shampoo, and scrub with a scotch Brite pad. After rinsing, I washed myself with IC hand cleaner. No itch in bed!
The absolute worst part of this job was the goggles. Within one minute of grinding they would fog up. I found no solution for this.
To tear out all wood, grind the hull, remove carpet glue and foam, clean out the hull, and clean up the workplace it took me 48 hours total.
Thanks for all the help, and I'll be back in April for more!
