revkev5064
- Jul 28, 2013
- 5
I am working on rebuilding a 1978 Cobalt and found something that I think is odd. The floor is in terrible condition and 4" holes have been drilled right into the compartments that contain the flotation foam. They were put there to mount the seats. In addition, the foam that is on the inside of the hull is about an inch thick and then glassed over - right over the foam. The 1" foam runs from the back of the boat up into the bow. Is that normal? Is that something that Cobalt did or is it possible that someone has redone this boat already? I was able to pull the fiberglass off the floor and sides in sheets.
I will post some pictures later but wondering if anyone else has run into what seems like very bad glass work.
