Brien S
- Nov 30, 2018
- 68
Hey all. New to the site. Tons of great info !!!
Picked up a project a few weeks ago for a pretty decent deal. Basically a trailer with a boat on it. Went into it knowing what it needs. Pulled the floor to find a previous hacked job of a new floor and partial stringer repair ( just cut the bad off and scabbed on new wood with no glass). I have it all out to the hull. Transome is rock solid ( whew !!!). Questions are, oem stringers are curved to try and follow the hull
starboard is more so than port. Could i just leave the new straight and add a couple of braces (bulk heads ?) Across the bow instead of havibg to bend the new 1x8's ? Also thinking of adding some 1/4" bracing on the outside of the stringers for more floor support. Thoughts about that ? Now onto glass. Been back and forth on what to use on the deck. Now thinking that a layer of 2oz mat topped with a layer of 6oz cloth is good. Also what would you recomend for tabbing ? Was thinking a layer of 6" 6oz then a layer of 8" 6oz.
Another thing that has me baffled. In the bottom of the hull they glassed in a bunch of appx 4x6 pieces of 1/2 plywood. Any idea why ?
