GSX455
- Aug 21, 2016
- 157
I got a 82 Renken w/ a Mercruiser 120 and I thought the motor was bad, but it turns out the outboard was seized Once I took the out drive off the motor would run. Fast forward as I'm pulling the motor out and the front motor mount, that bolts to the floor are dry rotted.
I've noticed folks here are really helpful, so I appreciate any advice.
The first picture is the fiberglass area showing where the motor mount goes, the second photo shows under the fiberglass it is hollow, so I would need to replace the wood. I'm guessing there is no easy fix, like injecting foam. If I take up the floor, I might as well do the other stringers under the floor, even though the floor feels pretty stable.
Can I just cut below the mount area and add wood, or does the whole floor need to come up?
Hope y'all had a good Thanksgiving, and thanks.
