calvinjwilcox
- Sep 7, 2018
- 12
Just purchased a 1982 Cobalt 19BR from the original owner, 569 hours, all original. Discovered a crack on the starboard side, fiberglass motor mount (on top of the mount). The crack is about 1" long and the actual mount has sunk into the fiberglass about 1/8". Does anyone know how these mounts were constructed? Are they hollow on the inside? Was it just a plywood box that was glassed over?
The plan was to pull the motor, cut out both mounts, and glass in new ones. Lately, I've considered saving the time and $$ and just pulling one mount at a time, and filling the fiberglass mount with an epoxy slurry (if they are hollow).
I have no concern that this crack is due to rot. Both motor mount bolts (large ones) were finger tight and I think the movement and vibration is what cracked the fiberglass. The port side looks perfect and both mounts do not appear to sit on a stringer. Everything else is super dry. This boat has been stored in a garage since new and continues to sit under a cover at my house. If I can get by with the simpler repair for a few years, I'll be happy. But I'm also not opposed to pulling the motor if that's what I have to do. It'll give me a chance to clean everything and paint the bilge. Anything else maintenance wise I should do if I do pull the motor?
Sorry for the long post but only 2 questions: How are these mounts constructed? Things to do when a motor is pulled.
Thanks for any input!
