Hello,
I recently purchased a 1993 sunbird corsair 170 with outboard and below deck 23 gal tank.
I have had fuel issues and bought a new fuel sender and pick up tube, both of the old ones were covered in grime/scale.
I cut in an access hatch in order to replace those parts as I only had a small round hatch before.
I have plenty of tools and some experience in woodworking and work on hvac equipment for my trade.
But... I made a drastic mistake by thinking I had a jug of coil cleaner to use on the top of the tank, but it turned out to be vinegar ............... Which obviously created a few pits in the tank, and one near the feeder that went all the way through.
My main question is can I repair these pits and the hole? Or do I make the even more time consuming job or cutting out the tank completely? I am also unsure if the vinegar made its way to places I cannot see? Pressure test the tank? The tank manufacturer RDS told me the tank is about 25x45x5 which makes it a good portion of the floor space of my boat and where I would probably have to remove my double seats on each side.
I was also planning on using pvc trim board to replace the existing part I cut out, either making it a hatch, or sealing it in and possibly carpeting over it something.
If I cut the whole tank out I would like to use pvc for that too, but realize I may need to secure it and seal it good for rigidity and moisture?
Thank you!
Thank you!
