I am on the ground floor of a transom and stringer refit on a 1988 searay cc 8' beam
i was wondering how many gallons of epoxy to get a job like this done?
FYI epoxy is NOT required for this job. You can use it if you want but it's a lot more expensive. Polyester resin will get the job done quite nicely and lot less money. You'll probably need a Minimum of 15 gallons of either one. Plus 15 yards of Glass. Check the link in my signature below for some helpful info on how to do the work.
Thanks i was looking for a base line on material i read that
epoxy sticks to anything where poly does not thanks for the response
i'll check out your sight
