Hello everyone !! I am new to boating and I have a question. I recently purchased a 1986 Sun Dancer 210B with a 4cylinder volvo and a 290A sp outdrive. The motor was not running when I purchased the boat but all I had to do was change a timing belt add a pertronix electronic ignition and change the oil. I have been using it for a bout 2 months now with out any issues. Here is my question though, I have a standard drain plug that I put into the lower part of the transom when I launch and then remove when I retrieve, standard right? but in front of my engine on the bottom of the bilge ( starboard side) there is another large drain plug. If you look under the boat there is a 3" in diameter black plug that comes up through the hull and has what appears to be a large plastic wing nut on the inside of the bilge. I always seem to have a little bit of water in the bilge when I remove the standard drain plug ( never bone dry) but not a lot. Yesterday we where out and I pulled the engine cover forward I could see a little stream of water flowing from that plug. So my question is what is this plug? should I pull it out and put plumber tape around the threads? should I even worry about it?
PS sorry for the long post!!
