Still at it. I've been tabbing my stringers in using pb fillets, and two tabs of 1708 all wet on wet.
The first picture is from my original batch of resin which went clear when wetting it out like most pictures I've seen, the next few pictures are of tabbing using resin from a different supplier, it wets out OK but after it kicks it is no longer clear and has an amber color just like whats left in the mixing cup , the resin is a marine grade from a well known supplier, any thoughts?
I ran out of my 1708 tabbing roll and an now cut strips from my 36" wide roll, is there a way to keep threads from pulling when wetting it out, I'm cutting the strips with a rotary cutter which leaves a clean edge but goes ugly when its worked.
