Jeffgrant00
- May 15, 2017
- 14
Update >
So i talked to the fella I bought the boat from again and he swears up and down that the standard rotation 305 is what was in the boat. 305k
He said the transmission is a 1.1 gear ratio and that even if it was supposed to be a reverse rotation engine that it wouldnt matter????? Now im allllllll confused. He said he had to get a ring gear machined amd pressed on so it would fit on the right side of the engine? Is he right, 1/2 right or all wrong?
He also said he has a double roller timing set put in it with a chain because it was heavier duty amd the the original engine was gear to gear. He as well told me.that he set it up for HEI ignition.
HELP!!?
HELP!!?
