I picked up this boat on accident for 500. Trailer is in great shape.
Motor seems like very low hours. Has 127 lbs compression in all 3 cyclenders. Carbs had to be scubbed, they were gunked up bad. Fuel pump is week and needs a rebuild (not able to run except at idle in the water). Other than that it has a ton of life left.
Boat is all aluminum including the floor. Everything is solid as far as I can tell. It has a slow leak took about 5 hours in the water to get an inch of water in the bilge. I'm thinking it came from the livewell. Previous owner stripped some of the carpeting and also drilled out some rivets in the floor. He also rewired the boat with speaker wire (I cried a little as there are exactly 0 fuses anywhere).
Wanting to turn this into a solid beater fishing platform and be able to use it for tubing and whatnot with the family. I do alot of fishing on smaller lakes with crap landings so it's gonna get beat on. I'm hopping to get this redone by next spring for crappies and walleye start. I've already planned out electronics as I was going to stick then on my other boat (another rehab project)
I've been reading alot of the rehabs posted here and getting some good ideas. Though I haven't found much info on a similiar all aluminum rebuild like this or much info on this model boat specifically. Hoping to get some info from you all.
Thanks for reading.
AJ in mpls.
Thanks for reading.
AJ in mpls.
