Woodonglass
- Dec 29, 2009
- 25,924
Just an FYI for others, If you know anyone with a Tow Truck with a crane. They can pull your motor quickly and easily. Call and check what the service call would be.
use a blower and blow the water off
Its not too bad... I can be a workout tho... in and out of the boat a billion times tweaking the lower adjustment nut. You'll get it tho... just make sure you don't drill the mount holes until you have the rear engine mounts installed because that will provide your lateral alignment... all you can adjust once they are lagged in is up and down.
