BayouWaters
- Jan 29, 2017
- 78
I am starting a full restoration on a recent purchase of a 18' 1989 Stratos Center Console boat and I thought some folks would like to follow along. I will certainly need some advice along the way.
When I first surveyed the boat the seller was trying to convince me that the boat was solid and just needed a motor. Upon inspection, the floor was solid and the transom had no hollow sounds when struck and no visible signs of flex. The gelcoat was slightly oxidized, but the hull appeared to be in great shape with only a few minor chips and scratches. When I opened the covers the glass over the stringers was completely delaminated and the inner transom skin was as well. The floor felt solid when you walked on it because of the amount of glass used on the outer skin, but the core was completely gone. There were tell-tale signs of issues with some minor spider cracks in the corners around the floor edges. Hard to tell what the original core was, but I think it was 1/2" plywood as that is what I found in one of the compartments. Anyway, needless to say I was able to get the project boat for a very good price.
My plan is to pull the cap off of the boat to access both the stringers and transom. I do not see any easy way to perform this restoration without pulling it. Cutting the top cap into pieces is just not in the cards for me. Any advice on how to properly support the hull prior to starting the restoration would be welcome. The boat is a 2 piece...hull and liner with floor, fish boxes, etc. all molded into it.
Pictures to follow...
