Can'tFishEnough
- Apr 19, 2011
- 86
Just about any of the tiller handles off of an OMC motor will fit, the throttle cable is the only thing you need to match up, but most cables can be made to work.
problem that I'm seeing with a "tiller conversion" is that it looks like the steering arm part of the motor is different between the electric start remote set up and the rope start tiller set up. The tiller one has a little bracket for the tiller to attach to. That part if even available it looks like you have to replace the whole steering arm that goes under the powerhead.
see #29 on parts diagram: http://www.iboats.com/Exhaust-Housing/dm/cart_id.405605912--session_id.396332139--view_id.1551365 long shaft replacement is around $600... and I'm not even sure if that is the one with the bracket or not... hence my comment about "makeshift" handle... even if I get a regular OMC tiller handle I still have to find a way to attach it to the remote steer bracket on the motor...
I think for the same amount of work and maybe cost - I've found a used steering set up for about $30, and will be able to get a console for it for about $150-180.
