imp0ster
- Apr 18, 2010
- 189
So I need a place to catalog everything and whoop here it is!! I bought this boat knowing it had bad steering and soft spots in the floor. It has a 355 from mid 2013 and silent choice
So far I have:
Rebuilt the bellhousing assembly,
New gimbal ring with NuWave SS pin
Installed Kenwood headunit/Polk MM 6x9s
Plumed in a faucet and water supply for the sink
Sanded down and spahr varnished the ski loccker hatch
Replaced the starboard lounge seat base with a marine cooler
Removed the the port lounge seat and made a step in out of cellular PVC and nonskid
Rebuild the entire center section with reinforced, encapsulated 3/4 Ply
Removed all the carpet and non skidididid the areas that don't need to be torn up for floor repair
Sanded and painted the outdrive, gimbal and transom assembly
Put on an Edelbrock 600 marine, Jegs wires, new pugs, new cap and rotor, new tygon vent line
Added two Optima blue top batteries and wired them in.
replaced fuel sender with WEMA unit.
Replaced all snap studs on the boat with SS
removed and replaced all through hull fittings and sealed everything.
Repaired platform ladder with 12"x5"x1/2" starboard and SS fender washers
Wired in 8 blue leds to flood the boat with light but hidden so it looks nice
Ripped up the back right side of the floor and removed rotten bulkhead and all the useless foam.
What I need to do:
Pour Arjay 6011 into transom
Rebuild rotten bulkhead and right rear floor with Nidacore
Rip up port floor under passenger chair and replace with nidacore
Remove the pin from the old steering arm, put new steering arm in and put bellhousing assembly back in
Replace all gauges with new white face Farias
Replace standard heads and 12 bolt intake with built Vortec 202 valve heads and edelbrock marine intake.
Wire in new Lowrance plotter/fishfinder
rebuild entire back seating area with nidacore
replace back sundeck wood with cellular PVC
I had more pictures of the tear down and what's been done so far but lost them. Since I'm doing all my own workand having dad help with the floor/bulkhead/transom stuff) it's actually not that expensive. I got 5g of resin for $80 from dad s well as some other parts
So far I have:
What I need to do:
