Re: Starter for 25 hp
Yes it can. You can probably get all the parts you need from
Twin City Outboards or your local outboard graveyard.<br />Here's a decked out
25hp Johnson to give you an idea of what it looks like. You'll need a starter, starter bracket, solenoid, wiring, battery and ignition switch to convert it. If your flywheel has no teeth you'll need that too, but I think they all did by '74.<br /><br />If your looking to make your outboard remote control, you'll also need a solenoid for the choke.
