Fixed Jet Carb to Adjustable?
stsmith
Johnson 55EL78S 55hp Type IV Carbs<br />Currently both carbs are fixed jets, <br />low speed and high speed. No med range<br />jet. Is it possible to make the idle<br />speed jets adjustable without replacing <br />the carbs?<br /><br />Smitty
walleyehed
Re: Fixed Jet Carb to Adjustable?
To my knowledge, no.....are you having idling issues????
stsmith
Idles good in neutral, but not in gear. If I speed the idle up in gear it runs away in neutral. <br />Idles way too fast with the ears on. It just seems to need a little tweaking. Carbs are clean with good compression. New plugs.<br /><br />Smitty
walleyehed
You need to be doing this in the water...You don't have the proper back pressure out of the water, to mess with the idle.
stsmith
I know that this was done in the water. Not with ears.<br /><br />Smitty
WillyBWright
Sounds like one of the butterflies is cracked a bit at idle. Make sure both are opening at the same time and fully closing at idle.
Dhadley
Have you done a decarb lately?
stsmith
Yes about 2 weeks ago. But it is an old engine that I bought so I was going to do it again this weekend.<br /><br />Smitty
