the is a manual release valve on the bracket either on the port or starboard side depending on if its a conventional or fastrac. it a flat tip slot, just take care when breaking it free so you dont enlarge the slot.
120 is a good motor- get your your self an omc service & parts manual.
i would spray some WD in the spark plug holes - let it set a day or so then try & spin flywheel by hand to make sure its free.
also make sure the WD straw does shoot into the plug hole.
carbs will need rebuilt also.
hope that helps
