I was getting ready to go duck hunting Friday afternoon and decided to run up my Honda 10 HP and my Johnson 40 HP Commercial. I filled a 30 gal drum, put the 40 HP in and it started right up after cleaning the starter motor brushes. The Johnson had no water out of the telltale or the exhaust. <br /><br />I pulled the pump apart and the impeller looks okay. It has a few circular rings worn in the cup and plate. Would these grooves cause it to not pump water?<br /><br />Where are the best prices on an impeller and full kit?<br /><br /><br />Model J40RWCT <br /><br />Serial # E5808***<br /><br />Thanks Harry
