I was trying to remove the lower unit on my 2000 Johnson 115hp OceanPro today when I hit a road block. I'm using the Seloc manual and it says to pull the pin on the shift rod linkage and free the shift rod from the shift linkage. Well after a little exploration I found the cotter pin and pulled it, however for the life of me could not figure out how the rod and linkage get disconected. I came back in the house and was thumbing through the exploded pictures and it looks like I'm supposed to pull the pin (which is near the center down real low in the front of the engine but slightly to the starboard side) and pull the shaft out from the port side. Am I on the right track?
